hibidwns
#1 Posted : Monday, June 25, 2012 1:44:16 PM(UTC)
hibidwns
The dryer was moved to a new location. When it was plugged in and the start button pressed it made a loud end of cycle buzz but would not start. The fuses, door switch, and voltage were all checked ok, I suspect the timer being faulty, but before spending $100 + would appreciate any advice.
#2 Posted : Tuesday, June 26, 2012 1:57:35 AM(UTC)
Are you sure it is the buzzer or is it the motor buzzing as it tries to start?
hibidwns
#3 Posted : Tuesday, June 26, 2012 3:52:47 AM(UTC)
hibidwns
The drum was turned by hand and the motor turned freely. The sound is from the buzzer located by the side of the timer.
#4 Posted : Tuesday, June 26, 2012 4:16:26 AM(UTC)
See the attachment for the tech sheet
Check that the BK/BU timer contacts are closed when trying to start it.
If not then it is the timer.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LER5636.pdf (240kb) downloaded 3 time(s).
electric dryer does not start (Microwave Repair)
by RayU 12/12/2013 7:03:52 PM(UTC)
Dryer does not start (Dryer Repair)
by Kalalau 9/20/2012 12:20:37 PM(UTC)
Belarus Bharat 1/7/2012 4:02:37 PM(UTC)
Dryer does not start, can hear motor attempting to (Dryer Repair)
by bog 11/5/2011 9:52:03 AM(UTC)
by Raymond S 8/4/2011 8:35:52 AM(UTC)
by cpboudreaux 2/15/2011 8:59:37 AM(UTC)
Dryer does not start - Amana Gas (Dryer Repair)
by timjgtr 1/8/2011 10:10:33 AM(UTC)
Dryer does not start at all (Dryer Repair)
by timjgtr 12/26/2010 2:40:08 PM(UTC)
Gae Dryer Does Not Start (Dryer Repair)
by B Wall 9/10/2010 7:03:40 AM(UTC)
by D_Druz 3/1/2010 4:41:38 PM(UTC)
Dryer does not start, makes no sound (Dryer Repair)
by Pennell 11/12/2009 5:17:16 PM(UTC)
dryer does not start (Dryer Repair)
by petecardenas 10/19/2009 8:17:02 AM(UTC)
by petecardenas 10/19/2009 8:15:29 AM(UTC)
by bellaboo 10/1/2009 1:16:49 PM(UTC)
Amana dryer does not start (Dryer Repair)
by Barjensen 8/5/2009 4:21:07 PM(UTC)
