Todd Rudaitis
#1 Posted : Monday, June 25, 2012 3:56:15 PM(UTC)
Todd Rudaitis
Hope someone can help...
I have a gas dryer that has been working flawless for the last 4 years. A month ago it stopped heating. I checked the thermostats and the thermal limiter. The limiter was blown.
I understand that a clogged vent is usually the problem. I checked the vent (which only about 6 feet long) and appears clear with good air volume coming through with the dryer running. I also checked the inside of the dryer including the lint chute. Everything seems really clean with just some fuzz here and there.
I figured that in theory, it should be one of the thermostats, so starting with the lowest one in the chain, I replaced the operating thermostat and installed a new thermal limiter.
It ran perfect for another three weeks, then popped the limiter again.
Today, I jumped the limiter and ran it on the medium setting. It ignites, but never seems to cycle the heat off...or maybe I didn't run it long enough for fear of over heating. But, when I run it on the low setting, it seems to cycle fine.
Ideas???
Thanks,
Todd
Orange, CA
#2 Posted : Tuesday, June 26, 2012 1:30:02 PM(UTC)
Hi Todd,
How long did you run it on high heat?
Did you have any load inside?
Todd Rudaitis
#3 Posted : Tuesday, June 26, 2012 7:00:40 PM(UTC)
Todd Rudaitis
Thanks for the reply...
Maybe 5-7 minutes??? With a load and without.
Todd
#4 Posted : Wednesday, June 27, 2012 12:48:58 PM(UTC)
5-7 minutes for the first time on a cold dryer is not bad. Then the flame should stay on for 2-3 minutes.
Todd Rudaitis
#5 Posted : Wednesday, June 27, 2012 5:24:01 PM(UTC)
Todd Rudaitis
Ok, if that sounds somewhat normal, then any ideas about why the thermal limiter keeps blowing??
Todd
#6 Posted : Wednesday, June 27, 2012 5:57:01 PM(UTC)
Restricted air flow through the vent and/or bad high limit thermostat.
