moody9207
#1 Posted : Sunday, June 24, 2012 1:00:30 PM(UTC)
moody9207
The icemaker in this unit has stopped making ice. The water dispenser works okay, so I know water is getting to the unit. If we put ice into the cavity, we can easily dispense the ice through the cubed or crushed ice switches. What can I troubleshoot?
#2 Posted : Monday, June 25, 2012 12:42:35 PM(UTC)
Make sure the water tube which comes into the ice maker is clean.
Swap the wires between the water valve solenoids. Push the water dispenser release for a few seconds and check if there is water inside the ice maker.
If there is water, replace the ice maker.
If there is no water, replace the water valve.
The model number you posted is incomplete. If you need the correct part numbers, verify the model number and repost it.
moody9207
#3 Posted : Monday, June 25, 2012 6:10:36 PM(UTC)
moody9207
Thanks Gene, where are these wires to the solenoids located? Any diagrams available?
The model number was taken directly off of the label inside the refrigerator side - this is what it says exactly:
HotPoint No-Frost CSX24D 23.6 cuft Refrigerator - Freezer
There are no other labels anywhere.
#4 Posted : Monday, June 25, 2012 8:28:23 PM(UTC)
Originally Posted by: moody9207 Go to Quoted Post
...where are these wires to the solenoids located? Any diagrams available?...
...The model number was taken directly off of the label inside the refrigerator side - this is what it says exactly:
HotPoint No-Frost CSX24D 23.6 cuft Refrigerator - Freezer...
The water valve is located on the back of the refrigerator. For the correct diagram I need the complete model number.
I hope the Model Number Locator will help you.
moody9207
#5 Posted : Sunday, November 3, 2013 1:41:42 PM(UTC)
moody9207
Hi Gene, I haven't worried about this because we have been just purchasing ice and loading the dispenser, but my wife reminded me that we should fix it, so I located this model number at the bottom - CSX24DMA. Hopefully that will allow you to provide the diagram. Thanks, Brian
