Joesquich
#1 Posted : 16 years ago
Joesquich
Hi
Problem is water keeps filling tub at high setting ok at low or medium
It possible could be the switch
question
the pressure switch hose where it conects to the tub has something in it that looks like it could be a clog or some kind of filter. In your picture of the part it shows a clear hose with no obstructions of any kind. Could this be the problem, that it's some debris that got into the line from the tub.
Thank you
Ydn4b0
#2 Posted : 16 years ago
Ydn4b0
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
woodchuckie
#3 Posted : 16 years ago
woodchuckie
Yes a blockage would be a problem. There should be nothing but air. The increased air pressure as it fill closes the switch. Take the tube off and clear it.
Kenmore washer overflowing (Washer Repair)
by wgreene 2 years ago
Whirlpool MFX2571XEM0 Icemaker water overflow into ice holding bin (Refrigerator & Freezer Repair)
by Guest 4 years ago
Kenmore 110.91310100 overflowing (Washer Repair)
by Dan T in SD 5 years ago
Fisher Paykel been overflowing now code 130 and stuck (Washer Repair)
by Gilligan8 6 years ago
water into detergent cup and overflows (Washer Repair)
by joeysgrandpa 7 years ago
water flows into detergent cup and overflows (Washer Repair)
water heater pouring from overflow pipe (Heating, Ventilation, and Air Conditioning (HVAC))
by paterry 7 years ago
GE Refrigerator ice maker overflowing!!! (Refrigerator & Freezer Repair)
by porksoda 7 years ago
Frig/Freezer Not Cooling/Overflowing Drain Pan (Refrigerator & Freezer Repair)
by merc1100sc 7 years ago
Washer keeps filling partway (doesn't overflow) (Washer Repair)
by CreoleRose 7 years ago
Drop pan overflowing (Refrigerator & Freezer Repair)
by Dqraider2 8 years ago
Dishwasher overflowing to floor, valve and float seems OK (Dishwasher Repair)
by rajdude 8 years ago
frigidaire refrigerator ice maker overflows ice (Refrigerator & Freezer Repair)
by Cee3PeeOh 8 years ago
Maytag washer fills / overflows by itself when off. (Washer Repair)
by Allyman 8 years ago
Upright freezer drip cup overflowing (Refrigerator & Freezer Repair)
by Homeschoolingmom6 8 years ago
