Thanks, I will take out the element first and double check the resistance. I cleaned the ice from everything and plugged the frig back in and it gets cold, so I know I have the correct general problem area identified.
I tried to run the forced defrost one more time before taking it apart and it worked. Do sure if I just had a bad connection or if I need to go back to your trouble shooting. Is the defrost thermosat the bimetl-def. I went back to your trouble shooting guide. It looks like the timer is the problem. Do you think I am correct.
P.S. I tested it again and the test worked as before. I also could hear the one "click" from the relay.
[COLOR="Blue"]I tried to run the forced defrost one more time before taking it apart and it worked. Do sure if I just had a bad connection or if I need to go back to your trouble shooting. [/COLOR] OK if I follow along you did not unplug anything in the evaporator coil area so I think you have it beat. [COLOR="Blue"] Is the defrost thermosat the bimetl-def.[/COLOR] Yes
[COLOR="Blue"]I went back to your trouble shooting guide. It looks like the timer is the problem. Do you think I am correct.[/COLOR] Yes I think you have found the problem as you can force the defrost heater on but the timer will not automatically do a defrost. The timer section of it is not working. Nothing is 100% guaranteed but I would replace the timer. |
THIS FORUM IS DEAD!!!!!!! |
HI, I am going through the same problem. The tech sheet link does not work - can somebody repost that? Originally Posted by: denman  I tried to run the forced defrost one more time before taking it apart and it worked. Do sure if I just had a bad connection or if I need to go back to your trouble shooting. OK if I follow along you did not unplug anything in the evaporator coil area so I think you have it beat.
Is the defrost thermosat the bimetl-def. Yes
I went back to your trouble shooting guide. It looks like the timer is the problem. Do you think I am correct. Yes I think you have found the problem as you can force the defrost heater on but the timer will not automatically do a defrost. The timer section of it is not working. Nothing is 100% guaranteed but I would replace the timer.
Please see the attachment |
