2 Pages<12
needhelp123
#11 Posted : Thursday, January 7, 2010 3:02:31 PM(UTC)
needhelp123
Thanks, I will take out the element first and double check the resistance. I cleaned the ice from everything and plugged the frig back in and it gets cold, so I know I have the correct general problem area identified.
needhelp123
#12 Posted : Thursday, January 7, 2010 3:20:47 PM(UTC)
needhelp123
I tried to run the forced defrost one more time before taking it apart and it worked. Do sure if I just had a bad connection or if I need to go back to your trouble shooting. Is the defrost thermosat the bimetl-def.
I went back to your trouble shooting guide. It looks like the timer is the problem. Do you think I am correct.
P.S. I tested it again and the test worked as before. I also could hear the one "click" from the relay.
#13 Posted : Friday, January 8, 2010 4:47:32 AM(UTC)
[COLOR="Blue"]I tried to run the forced defrost one more time before taking it apart and it worked. Do sure if I just had a bad connection or if I need to go back to your trouble shooting. [/COLOR]
OK if I follow along you did not unplug anything in the evaporator coil area so I think you have it beat.
[COLOR="Blue"]
Is the defrost thermosat the bimetl-def.[/COLOR]
Yes
[COLOR="Blue"]I went back to your trouble shooting guide. It looks like the timer is the problem. Do you think I am correct.[/COLOR]
Yes
I think you have found the problem as you can force the defrost heater on but the timer will not automatically do a defrost. The timer section of it is not working.
Nothing is 100% guaranteed but I would replace the timer.
gvrsek
#14 Posted : Saturday, June 23, 2012 3:58:38 AM(UTC)
gvrsek
HI,
I am going through the same problem. The tech sheet link does not work - can somebody repost that?
Yes
Yes
#15 Posted : Sunday, June 24, 2012 2:44:33 AM(UTC)
Please see the attachment
File Attachment(s):
GD25DI.pdf (167kb) downloaded 9 time(s).
2 Pages<12
