apprik
#1 Posted : Wednesday, June 20, 2012 5:39:48 AM(UTC)
apprik
The washer performs normally until it reaches the point to drain the tub & spin. It will completely stop then, leaving the tub full of water (and wet clothes).
Advancing the dial does nothing to help, however, at some of the other dial positions, the timer can be heard "humming/buzzing".
Based on the prices of new machines, I would like to repair the old one. Also, since new timers are also expensive, I would like to make sure that I check other possible parts.
So far, all we have done is to manually check every other position of the dial (no help except that the humming noise occurs at some points), and made sure that the lid switch was being contacted by the tab on the lid.
Thanks for any suggestions.
Simon / APP Team
#2 Posted : Wednesday, June 20, 2012 9:47:09 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unplug the washer. Open the control panel, disconnect the lid switch plug and using the multimeter check the continuity between outer contacts (lid closed).
No continuity - replace the lid switch Part number: 3949247
Use the video clip for the instructions.
Here are the breakdown diagrams and Replacement parts for Whirlpool LSN1000KQ0 WASHER - DIRECT DRIVE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
apprik
#3 Posted : Friday, June 22, 2012 8:50:53 AM(UTC)
apprik
The suggestion that the problem may be the lid switch was exactly correct. For now, I have bypassed the switch and the washer is working fine. There is still the new noise (humming/buzzing) coming from the timer. It may be going bad too. I'll worry about some other day.
Execellent help. Thanks.
-Rick W.
Simon / APP Team
#4 Posted : Friday, June 22, 2012 10:12:21 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Rick.
Don't use the washer with the lid switch bypassed. It's dangerous specially if there are kids in the house.
Replace the lid switch.
Simon.
Guest (4)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
Maytag Washer Will Not Drain or Spin during White or Color Cycle (Washer Repair)
by ametz69 11/6/2012 5:52:41 PM(UTC)
Top loan washer will not drain or spin (Washer Repair)
by Tom Roberts 4/26/2012 9:03:03 AM(UTC)
LG washer will not drain or spin (Washer Repair)
by rangers02 10/12/2011 2:51:22 PM(UTC)
Roper washer will not drain or spin? (Washer Repair)
by Burns5150 9/3/2011 6:50:17 AM(UTC)
Washer will not drain or spin on final rinse. (Washer Repair)
by link888 3/24/2011 7:38:52 AM(UTC)
by link888 3/24/2011 7:32:23 AM(UTC)
Washer will not drain or spin. (Washer Repair)
by albouldin 12/3/2010 9:21:23 AM(UTC)
by RHUTCH 8/17/2009 2:57:11 PM(UTC)
Whirlpool washer will not drain or spin. Is it the lid switch? (Washer Repair)
by conramana 6/10/2009 7:48:12 PM(UTC)
whirlpool washer will not drain or spin (Washer Repair)
by llbishop7@cs.com 5/4/2009 8:47:22 AM(UTC)
Washer will not drain or spin when loaded (Washer Repair)
by Roc1966 12/11/2008 3:37:57 AM(UTC)
