robbob41
#1 Posted : Tuesday, June 19, 2012 4:36:17 PM(UTC)
robbob41
hello my freezer is icing up and the blower motor for the evap core is not running. i have no manual for this freezer and do not know where the heater or the timer switch is located. the model # is frs26lf8cs2
thank you
rob
#2 Posted : Wednesday, June 20, 2012 12:58:14 AM(UTC)
Replacement parts for Frigidaire FRS26LF8CS2 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...f/Anderson/240389616.pdf
And the operators manual
http://manuals.frigidaire.com/p...Anderson/240389311en.pdf
[COLOR="DarkRed"]do not know where the heater or the timer switch is located.[/COLOR]
The defrost heater is Item 14 in Section 9.
The unit uses a defrost board Item 23 in Section 2.
Also the defrost thermostat is Item 21 in Section 9.
[COLOR="DarkRed"]freezer is icing up and the blower motor for the evap core is not running.[/COLOR]
The most likely cause is the defrost board as it controls both defrost and the evaporator fan.
I would try to force a defrost cycle just to see if it will heat up.
If it does then I would replace the board.
If it does not heat up it does not eliminate the board as the problem and you will have to check the heater and the defrost thermostat. If both check out OK then I would replace the board.
Would not be a bad idea to check for 120 volts across the fan just in case it is toast and no fan and no defrost is just a coincidence.
Top freezer icing up after power outage (Refrigerator & Freezer Repair)
by Markgova 3/15/2014 6:50:08 AM(UTC)
Freezer icing up on coil sides (Refrigerator & Freezer Repair)
by nackster 2/19/2014 5:08:13 PM(UTC)
Refrigerator Freezer icing up (Refrigerator & Freezer Repair)
by star95presson 10/14/2012 9:18:40 AM(UTC)
by CapeCod53 6/21/2012 4:44:55 AM(UTC)
Amana frost free freezer icing up (Refrigerator & Freezer Repair)
by Kelland 6/1/2012 11:48:02 AM(UTC)
Kenmore elite freezer icing up (Refrigerator & Freezer Repair)
by ebjorge 2/2/2012 12:36:26 PM(UTC)
Amana Bottom Freezer Icing Up (Refrigerator & Freezer Repair)
by mmsullivan 1/12/2012 1:28:04 PM(UTC)
kenmore freezer icing up (Refrigerator & Freezer Repair)
by czubiak1 12/14/2011 6:57:07 PM(UTC)
Freezer icing up near thermistor (Refrigerator & Freezer Repair)
by asrstech 11/21/2011 1:19:11 AM(UTC)
bottom of freezer icing up (Refrigerator & Freezer Repair)
by wyattearp 10/28/2010 6:43:15 AM(UTC)
by aturchin45@hotmail.com 9/4/2010 6:14:14 AM(UTC)
Freezer icing up Fridge not at 60 degrees (Refrigerator & Freezer Repair)
by chrisze 8/21/2010 2:50:34 PM(UTC)
freezer icing up frig warm (Refrigerator & Freezer Repair)
by hotbox 8/10/2010 11:43:17 AM(UTC)
Freezer icing up, runs continually,refer compartment warming up (Refrigerator & Freezer Repair)
by lawnan 4/23/2010 8:21:26 AM(UTC)
Freezer icing up, fridge freezing, thermostat, timer, and defrost heater check out. (Refrigerator & Freezer Repair)
by sharkytm 1/9/2010 12:29:17 PM(UTC)
