In Door Dispenser dispenses water but not crushed or cube ice. I can open the door open while holding the door switch and I can see the auger turning and hear the motor running but no ice. I can switch between crushed and cube and see the gear reverse. Any ideas on what part I need to fix this with since the motor and reverse appear to work properly. Thanks, Greyson1
Groups: APP Team
Hi.
Remove the ice bin and check: -if the ice door opens -is there any blockage at the bottom of the ice bin Rotate manually the auger (while the bin is out) and try to locate the problem.
Thank you.
Simon.
:) :) I took out all of the ice and did the test you mentioned. I also ran HOT water over the bottom of the ice bin and it started to work. I will watch it to make sure it continues to work. Thanks for the quick answer. Regards, Greyson
Groups: APP Team
You are very welcome.
Simon.
