I have a GE dryer DJXR433EG1WW HM724989A
I JUST replace the heater element and put it all back together, question: is it ok for it to look red hot in the back when its on hi I have never done this befoer? also the dryer will not stay on unless I hold the on button on its position and it was working before please help
Groups: APP Team
Hi. You should check the idler spring switch (actuates by the idler pulley spring next to the motor) and belt. The switch Part number: WD21X10261
