JoeHipp
#1 Posted : Tuesday, June 12, 2012 5:12:05 PM(UTC)
JoeHipp
Dryer runs too hot regardless of setting. Dryer was disassembled and cleaned out completely although the vent was not blocked to begin with (first thing checked). Replaced the following parts with new ones even though they all checked out fine with ohm meter:
Thermal Fuse: 3392519
Thermistor: 8577274
High Limit Thermostat: 3403140
I also checked the Radiant Sensor (338906) thinking it might not be allowing the flame to kick off or something and it checked out fine on the ohm meter. This part was not replaced.
Dryer still runs hot. Any suggestions on what to check next? Thank you very much!
#2 Posted : Wednesday, June 13, 2012 5:41:12 PM(UTC)
Disconnect the vent hose from the dryer and run a load. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool GGW9868KL2 27"GAS DRYER | AppliancePartsPros.com
GE Dryer gets too hot (Dryer Repair)
by Bud_Jones 10/8/2014 9:41:09 AM(UTC)
replaced faulty heating element, now dryer gets too hot. Help please! (Dryer Repair)
by sheriowaso 11/15/2013 4:21:37 PM(UTC)
Whirlpool GEW9250 dryer gets too hot (Dryer Repair)
by kp1 6/17/2011 2:30:17 PM(UTC)
dryer gets too hot on every heat setting (Dryer Repair)
by jmack123 6/14/2011 3:59:40 AM(UTC)
by bob55 7/25/2010 4:15:18 AM(UTC)
by markscoolstuff 8/20/2009 7:55:10 AM(UTC)
Replaced element, dryer gets too hot (Dryer Repair)
by Piita 6/14/2009 7:48:40 PM(UTC)
Electric dryer gets too hot (Dryer Repair)
by cojo1957 10/27/2008 4:08:44 PM(UTC)
