konfla
#1 Posted : Thursday, June 7, 2012 4:32:35 PM(UTC)
konfla
Freezer seems normal but refrig not cold enough. finally noticed that no matter what i set digital control to, as soon as I close the door it sets itself to 12deg & 33deg.
Fan seems to work and damper seems to work. What a piece of junk!
konfla
#2 Posted : Sunday, June 10, 2012 3:55:26 AM(UTC)
konfla
is there a way to ohm out the sensor? Where is the sensor? Dont want to buy parts that aren't for sure broken
#3 Posted : Monday, June 11, 2012 12:29:46 AM(UTC)
You are not getting good advice. Pull the back freezer panel and descibe the frost patrtern, total, heavy frost or partial.
konfla
#4 Posted : Monday, June 11, 2012 1:54:41 PM(UTC)
konfla
Hahaha! thanks guys, i need all the advice i can get so i appreciate both of you helping out.
Cleaned the coils but not too dirty. The icemaker is working good. I took the cover off the electric damper and it seems to work better now. No problem with frost, but i did not remove back cover of freezer yet.
Thanks again for everyones help!
