Freezer seems normal but refrig not cold enough. finally noticed that no matter what i set digital control to, as soon as I close the door it sets itself to 12deg & 33deg. Fan seems to work and damper seems to work. What a piece of junk!
is there a way to ohm out the sensor? Where is the sensor? Dont want to buy parts that aren't for sure broken
You are not getting good advice. Pull the back freezer panel and descibe the frost patrtern, total, heavy frost or partial.
Hahaha! thanks guys, i need all the advice i can get so i appreciate both of you helping out.
Cleaned the coils but not too dirty. The icemaker is working good. I took the cover off the electric damper and it seems to work better now. No problem with frost, but i did not remove back cover of freezer yet. Thanks again for everyones help!
