2 Pages12>
tbosu
#1 Posted : Saturday, March 28, 2009 1:05:15 PM(UTC)
tbosu
Have Whirlpool side by side with ice maker. A while back the ice maker was not working and I found ice jammed in the ice maker, after removing it worked fine for a while but now has quit working. It appeared that there was no water going into the ice maker so I replaced the water inlet valve and it still will not work. I checked the electrical plugs on the inlet valve and I am not getting any power on the ice maker side in the plug. Could this be a bad modular? Any help will be appreciated before spending more on further parts.
kayakcrzy
#2 Posted : Saturday, March 28, 2009 1:26:40 PM(UTC)
kayakcrzy
i am assuming that water is coming to the water valve, so the first thing i want you to do is to make sure that the tube that puts the water into the icemaker is not froze up. it is possible that it is frozen with ice. let me also tell you how to jump out the icemaker. pull the front off, and make you a jumper wire about 6 inches long, and just strip the wire back on each end, about a half inch, and then put 1 end in the hole marked m, and the other in the whole marked n, and if the icemaker head is good, it will take right off, if it does count till 12, and then take the wire out, and watch the icemaker, and see if when it stops you should have water in it. if the icemaker front gear does not turn when you put the jumper wire in replace the motor module. the part # is 8201515. tom
tbosu
#3 Posted : Saturday, March 28, 2009 3:52:41 PM(UTC)
tbosu
tried to jump out the ice maker as you suggested. No results, thus the motor module is probability bad? Did check out earlier testing points L & N and also jumper test points T & H and it showed they both had power.
kayakcrzy
#4 Posted : Saturday, March 28, 2009 4:18:28 PM(UTC)
kayakcrzy
You have it. Replace the motor module. Let me know how it goes. Tom ApplianceEducator.com
tbosu
#5 Posted : Sunday, April 5, 2009 4:08:28 AM(UTC)
tbosu
I replaced the motor module and and appears to be turning the white dial but still not working. There is water in the ice maker. I jumped started the new module as you suggested that I try on the old one but with no results. I have replaced the inlet valve and this motor module and have over $100 in parts already, do you have any other suggestions or tests to check for problem?
kayakcrzy
#6 Posted : Sunday, April 5, 2009 6:09:23 AM(UTC)
kayakcrzy
Have you given it 24 hours? The only other thing I could think of is the sensor inside the body section of the icemaker is bad. Just so I understand you, you jumped it out, and it filled, and it has ice, and it is not dumping it. The other thing I am thinking of is the heater could be bad, and the icemaker can't dispence the ice. Tom ApplianceEducator.com
tbosu
#7 Posted : Sunday, April 5, 2009 8:44:30 AM(UTC)
tbosu
It appears there is water in tray but it is not making any ice. I have no ice and of course it is not dumping any ice since there is none.
kayakcrzy
#8 Posted : Sunday, April 5, 2009 2:43:33 PM(UTC)
kayakcrzy
It would have to be the sensor. Tom
tbosu
#9 Posted : Sunday, April 5, 2009 2:53:35 PM(UTC)
tbosu
Would I have to replace the entire ice making unit or can I just replace the sensor, where is the sensor located and would you know what the part number is? Appreciate all your help to date.
kayakcrzy
#10 Posted : Monday, April 6, 2009 4:20:44 AM(UTC)
kayakcrzy
the thermostat can be replaced. the part # is 627985. this is usually the problem, when you can jump the icemaker out, and it works fine, but after that it won't make any ice. tom
Guest (11)
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Kennmore icemaker does not work (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:57:24 AM(UTC)
ICEMAKER ISSUE: Kitchenaid KSRS27QFAL00 Superba (Refrigerator & Freezer Repair)
by jselko 10/14/2023 1:30:11 PM(UTC)
Icemaker for Kenmore 106.51764510 (Forum Announcements)
by jzannini 9/26/2023 12:37:24 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
MFI2269VEM2 icemaker quit (Refrigerator & Freezer Repair)
by Smoreschnapps 5/22/2023 7:06:31 AM(UTC)
GE Undercabint Icemaker (Refrigerator & Freezer Repair)
by rjcunning 4/9/2023 7:35:53 AM(UTC)
no noise when push buttons on icemaker to dispense ice (Refrigerator & Freezer Repair)
by Messenger12 2/27/2023 3:06:18 AM(UTC)
New icemaker failed (Refrigerator & Freezer Repair)
by 7Pat 12/18/2022 11:40:20 AM(UTC)
Buy (200 Pcs) New Insignia - 44 Lb. Portable Nugget Icemaker $39,800 (General Talk)
by eikohajime30 11/9/2022 10:16:55 PM(UTC)
Icemaker Voltage at freezer wire harness (Refrigerator & Freezer Repair)
by mcouvillon 11/1/2022 8:37:12 AM(UTC)
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 10/10/2022 2:52:08 PM(UTC)
sub zero icemaker uc15 (Refrigerator & Freezer Repair)
by Guest 9/25/2022 7:21:16 AM(UTC)
2 Pages12>
