Eric1974
#1 Posted : Friday, June 8, 2012 1:37:59 PM(UTC)
Eric1974
Groups ready for retrieval: Registered
The washer has stopped draining completely at the end of a cycle. I've checked the check valve and confirmed it is clear. I've also confirmed solid discharge at the air gap. I'm not sure what direction to go with this. Timer problem? Broken/worn discharge impeller? If I pull the pump to check the impeller - do I need to replace a gasket? Thanks for any help.
#2 Posted : Friday, June 8, 2012 6:06:20 PM(UTC)
Originally Posted by: Eric1974 Go to Quoted Post
...I've checked the check valve and confirmed it is clear...
Did you unscrew it from the pump?
- The check valve Part number: 675238
Part number: 675238
Eric1974
#3 Posted : Friday, June 8, 2012 6:12:11 PM(UTC)
Eric1974
Yes. I also flushed water through the valve and it appeared to be functioning correctly. I have also determined the washer drains completely twice during the wash cycle.
#4 Posted : Friday, June 8, 2012 6:26:49 PM(UTC)
How much water left in the dishwasher at the end of the cycle? Did you check it right after the cycle was done or sometime later?
Eric1974
#5 Posted : Friday, June 8, 2012 6:32:03 PM(UTC)
Eric1974
I am checking it right away. There is probably a couple of inches of water.
Eric1974
#6 Posted : Friday, June 8, 2012 6:39:45 PM(UTC)
Eric1974
It just went through the entire rinse cycle without draining. The dry cycle starts with water over the coil.
#7 Posted : Saturday, June 9, 2012 5:07:09 PM(UTC)
Did it keep rinsing until it came to drying?
If it did, replace control board.
- The control board Part number: 8530929
gene.
