2 Pages<12
Jaybda2nd
#11 Posted : Thursday, June 7, 2012 9:59:35 AM(UTC)
Jaybda2nd
Originally Posted by: Jaybda2nd Go to Quoted Post
I'm having a helluva time putting the ribbon cable back in. Any suggestions?
I got it, it helps when u take the clip off. Duh. All workie now. Thanks fellas.
c.p.hansen
#12 Posted : Thursday, June 7, 2012 10:26:17 AM(UTC)
c.p.hansen
I can tell you the issue and solution I had. There's a small plastic retainer that holds the cable in place on the board. The retainer came away with the cable when I removed the cable from the old board. However, the new board comes with the retainer already installed. You need to take the retainer off of the new board, slide it over the bare ribbon cable, gently press the cable into its slot, and slide the retainer down to lock it in. If you leave the new retainer in and try to install the cable with the old retainer still on the cable, it won't work. Because of poor access, it took a few minutes for me to realize the new board had a retainer already installed. Hope that makes sense and helps.
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 7/4/2022 6:46:54 PM(UTC)
Thermador PG304BS/09 Oven Problem (Oven Repair (including Ranges and Cooktops))
by Guest 8/15/2021 7:27:03 PM(UTC)
Range oven problems. (Oven Repair (including Ranges and Cooktops))
by jorge osorio 1/29/2019 1:16:21 PM(UTC)
Oven Problem - lower, no heat; upper A-OK (Oven Repair (including Ranges and Cooktops))
by gesche444 9/15/2017 12:21:36 PM(UTC)
Oven problem (Oven Repair (including Ranges and Cooktops))
by Lhodges 1/28/2017 10:58:04 PM(UTC)
Kitchen Aid oven problem (Oven Repair (including Ranges and Cooktops))
by Rawger11 9/2/2014 11:13:56 AM(UTC)
Maytab oven problem (Oven Repair (including Ranges and Cooktops))
by DJ5140 3/16/2014 8:43:29 AM(UTC)
Whirpool Oven Problems (Oven Repair (including Ranges and Cooktops))
by phsffaman 2/15/2014 6:35:40 PM(UTC)
Oven problem during self clean cycle (Oven Repair (including Ranges and Cooktops))
by cgoetzfried@att.net 1/21/2014 5:48:07 PM(UTC)
kitchenaid oven problem (Oven Repair (including Ranges and Cooktops))
by ticat900 11/25/2013 11:06:28 AM(UTC)
Range/oven Problem (Oven Repair (including Ranges and Cooktops))
by slongo 10/22/2013 5:06:51 AM(UTC)
GE Profile Oven Problems (Oven Repair (including Ranges and Cooktops))
by RSF 10/16/2013 10:23:15 PM(UTC)
by Whizknot 10/7/2013 7:31:01 PM(UTC)
self cleaning oven problem (Oven Repair (including Ranges and Cooktops))
by preachergirl09 9/8/2013 11:20:21 AM(UTC)
wall oven problems (Oven Repair (including Ranges and Cooktops))
by jethro75 8/1/2013 6:35:09 AM(UTC)
2 Pages<12
