MY WHIRLPOOL JUST QUIT FREEZING AND COOLING. WHAT WOULD THE PROBLEM BE? THERE WAS A LOT OF DUST UNDER THE REF.....:mad:
Check to see if the condenser fan at the back underneath the fridge is running. Is the compressor motor near that fan running. Is it warm or room temp. Are the coils warm ,cold or hot.
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. stopped up? clear? ice in one spot . frost everywhere.
woodchuckie, hanks for letting me know what to check. all fans are running,,, but the compresser is hot or very warm and it clike off when it trys to run
