Maytag washer will not stop filling,will stop if disconnected from mains,replaced water pressure switch,still same,tried lightly blowing into pressure switch with water running did not stop flow of water, could hear switch click when pressure released.:mad:
What is the serial number of the washer?
Hi Gene, Serial # 20078822CN Maytag top load washer. Thank you.
Make sure the pressure hose between the pressure switch and the outer tub is clear and not pinched and/or kinked. Disconnect the hose from the pressure switch and blow some air through the hose. Did it go through? What is the part number of the pressure switch you installed? The correct pressure switch Part number: 21001882
I purchased a new switch from ApplianceParts Pros, I have blown down the hose and could hear water bubbling in the bottom of the tub
Hi Gene, could you please point me in the right direction has to why my washer will not stop filling,we have a small child in the house so I need to try and get this machine repaired as soon as possible.
Thanking you
Limey:confused:
Hi Limey, You did not confirm the part number of the new pressure switch yet. If this is the same part number I posted, procced to the following steps. Remove the front panel and lift the top panel up. Remove the wires from the water inlet valve while the washer is overfilling after it reached a set level. If it would not stop filling, replace the water inlet valve. If it would stop filling, replace the timer. - The water inlet valve Part number: 21001932
Hi Gene,
Thank you for your time and patience, it turned out to be the timer,thanks again.
limey:)
You are welcome Limey. I'm glad you were able to fix it.
