Hi. The fast track service manual for the Samsung dryer model # DV219AGW/XAA will be sent. The gas valve is Part number: AP3845027
. The bubble leak detector is Part number: AP3766089
. Good luck. Thank You. Originally Posted by: Replacement  Where can I find a service manual that shows how to get to the gas valve in the dryer?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The noise may be the drum seam .
