My wife found a royal blue rubber ring, approximately 8-inches in diamter on the bottom of the tub between the heater and below the spray arm. Is this a part of the dishwasher? If yes, where does it go and how would I reattach/reinstall this part? Please see the attached pictures. Thanks in advance for your help!! e4nf3 attached the following image(s):
Hi there, I have exact same problem. Ring is not broken and assume I overloaded one of the dishwasher racks. If you have figured out where the ring goes I would appreciate any help. Take care
THIS FORUM IS DEAD!!!!!!! |
i found the SAME exact ring in my kenmore. But I have looked at the parts list and cannot find where it goes or a replacement. Did you find an answer?
