e4nf3
#1 Posted : Sunday, April 3, 2011 11:09:59 AM(UTC)
e4nf3
My wife found a royal blue rubber ring, approximately 8-inches in diamter on the bottom of the tub between the heater and below the spray arm. Is this a part of the dishwasher? If yes, where does it go and how would I reattach/reinstall this part?
Please see the attached pictures.
Thanks in advance for your help!!
e4nf3 attached the following image(s):
Hockeyplayer
#2 Posted : Monday, June 4, 2012 9:53:28 AM(UTC)
Hockeyplayer
Hi there,
I have exact same problem. Ring is not broken and assume I overloaded one of the dishwasher racks. If you have figured out where the ring goes I would appreciate any help. Take care
#3 Posted : Thursday, June 7, 2012 2:53:04 AM(UTC)
Here are ypur parts
Replacement parts for Whirlpool DU948PWPQ2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
It does not look like you will get a reply.
I do not know where it goes as it seems too big.
If you click on the picture pump cover seal (Item 13 in Section 4) a new page will open with info on it.
Problem is it looks smaller (~5.5 inch diameter) using the grid which is 1 inch per square.
williamske
#4 Posted : Monday, November 12, 2012 5:29:28 PM(UTC)
williamske
i found the SAME exact ring in my kenmore. But I have looked at the parts list and cannot find where it goes or a replacement. Did you find an answer?
Guest (4)
