ncalvano
#1 Posted : Saturday, August 15, 2009 10:48:06 AM(UTC)
ncalvano
My Whirlpool washer tends to skip the spin cycle or run water during the spin cycle. I was thinking of changeing the timer... Does any one have any suggestions??
sidfink43
#2 Posted : Sunday, August 16, 2009 6:14:52 AM(UTC)
sidfink43
Can you give us a more detailed description. When you say it skips the spin cycle does the timer continue to run, or does the entire process stop? Does this happen after the agitate and rinse cycles or just one?
If you can gives us all the pertinent info (don't worry about giving too info) we may be able to confirm the timer or suggest another area.
ncalvano
#3 Posted : Sunday, August 16, 2009 7:46:54 AM(UTC)
ncalvano
It seems like the timer continues to run. I ran it thru the spin cycle only, one time water continued to run thru the spin cycle, another it did not spin at all. I took of the top and tapped on the timer and know it seems to be working. This is in the regular wash cycle I have not tryed any of the other cycles. Thanx for your help..
sidfink43
#4 Posted : Sunday, August 16, 2009 9:15:16 AM(UTC)
sidfink43
Ok, let us know what it does in other cycles.
Sounds like a timer issue but let's try to eliminate other things before you invest in a new timer.
mopalittle1
#5 Posted : Saturday, June 2, 2012 4:36:59 PM(UTC)
mopalittle1
where are the icons located that you keep asking me to click on to get a quick reply?
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Whirlpool Washer spin cycle wobble (Washer Repair)
by uruiamme 5/9/2014 3:55:11 AM(UTC)
Whirlpool Washer Spin Cycle Problem (Washer Repair)
by rbyeway 11/8/2011 7:49:07 AM(UTC)
Whirlpool Washer Spin Cycle Noise (Washer Repair)
by radiodudek 1/9/2010 7:20:42 AM(UTC)
by lk12835 11/23/2009 3:24:36 PM(UTC)
Whirlpool washer spin cycle sporadic? (Washer Repair)
by crowes5 9/5/2009 7:25:31 PM(UTC)
Whirlpool washer spin cycle doesn't remove all the water (Washer Repair)
by suepar 9/29/2008 3:51:24 PM(UTC)
