jeff69
#1 Posted : 14 years ago
jeff69
I have a maytag nepyune front load washer leaks water out the front door!
a little stream at first then a couple then gushes! had it serviced they put in all gaskets and seals and the big rubber drain surround between the tub and the front!! :confused: :( :mad: :eek:
sidfink43
#2 Posted : 14 years ago
sidfink43
Assuming you used a reputable service firm, get them back and get them to fix it.
NeptuneHelp
#3 Posted : 13 years ago
NeptuneHelp
I would also check to make sure it is not over filling machine. Normally, the water level is so low that it should not even come out the door. The water level detector could be starting to fail. See neptune washer for more Neptune tips...
Until next time...
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 5 years ago
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 6 years ago
Maytag neptune washer logic board (Washer Repair)
by Busch58 7 years ago
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 9 years ago
Maytag Neptune Washer Clutch Replacement (Washer Repair)
by helplessm355 10 years ago
maytag neptune washer MAH9700AWM wont spin (Washer Repair)
by biztyke 10 years ago
Maytag Neptune Washer Shuts off After Water Fill (Washer Repair)
by kluskc 11 years ago
Maytag Neptune Washer will not spin (Washer Repair)
by BStevens82 12 years ago
Maytag Neptune washer code uc (Washer Repair)
by Jef_R 12 years ago
Maytag Neptune Washer shuts off (Washer Repair)
by HHB 12 years ago
Maytag Neptune Washer Spin Cycle Noise (Washer Repair)
by jayjaysin 13 years ago
maytag neptune Washer (Washer Repair)
by alfonso m 13 years ago
Maytag Neptune washer & dryer reputation (Washer Repair)
by LLLN 13 years ago
Maytag Neptune Washer - cold won't fill (Washer Repair)
by sandylouwhoo 13 years ago
