mf10929
#1 Posted : Sunday, May 27, 2012 6:45:03 PM(UTC)
mf10929
My freezer started making a buzzing and clicking sound right after it shuts off. It also seems to be cycling too often. I timed the cycles at 7 minutes on and 7 minutes off. About 20 seconds after it shuts off, I hear a buzzing sound for about 4 seconds then a click. I can hear the oil moving and the freezer is staying cold. Could it be the starter relay?
#2 Posted : Monday, May 28, 2012 1:43:54 AM(UTC)
Seems like a bad cold control, AP2153219
mf10929
#3 Posted : Monday, May 28, 2012 7:53:47 AM(UTC)
mf10929
That was my first thought. Changing the thermostat setting didn't change the way the freezer is acting. It has been set at the lowest setting of 1 for nearly all of its life.
#4 Posted : Monday, May 28, 2012 8:05:55 AM(UTC)
If you can, monitor the voltage to the compressor. Any voltage to the compressor soon after shutoff, will make it hard starting.
mf10929
#5 Posted : Thursday, May 31, 2012 3:35:03 PM(UTC)
mf10929
Thanks for the input. It is the thermostat. When the overload starts buzzing, I can tap the thermostat with a screwdriver handle and it stops.
