What is the impact of using WD40 on rollers?
Not sure what you mean.
I can say that WD-40 is not a great lubricant. You are much better off with sewing machine or 3 in 1 oil. |
THIS FORUM IS DEAD!!!!!!! |
I can say that WD-40 is not a great lubricant. You are much better off with sewing machine or 3 in 1 oil. Also do not go crazy with the oil as it will hold lint. |
Originally Posted by: denman  Not sure what you mean.
I can say that WD-40 is not a great lubricant. You are much better off with sewing machine or 3 in 1 oil. Also do not go crazy with the oil as it will hold lint. I was reading one of threads and it mentioned not to use WD-40, which I did obviously. I was wondering the downside of using it.
It just does not last very long so you end up having to re-oil it. |
