I have a Maytag Dishwasher, purchased in December '09, and has worked fine. However, yesterday I tried to use it, and it won't start. It seems to latch OK. The "Light" cycle light will light up when pushed, and the "Sanitize" light will blink when pushed, but no other buttons show any activity. Model # MDBH979AWW3 Serial # FY4703035 Type 577-0 Got any ideas? Thanks, JD
Originally Posted by: Gene  Hi Gene, Thanks a bunch for the reply. I've been gone for awhile, but now it's time to fix this dishwasher. I've got a white maytag. I'd like to start by replacing the control panel. Can you point me in the right direction for info on parts and procedure for replacement, please? Thanks, JD
Hi JD, The white control panel Part number: W10254847
In order to remove it you have to remove the inner door panel first by removing the Torx screws along the sides and top of the inner door panel. Remove the PC board housing cover and disconnect the membrane switch from the PC board. Remove the PC board. Lift out the latch assembly. Remove the 4 screws securing the control panel to the outer door. Gene.
Originally Posted by: Gene  Hi JD, The white control panel Part number: W10254847
In order to remove it you have to remove the inner door panel first by removing the Torx screws along the sides and top of the inner door panel. Remove the PC board housing cover and disconnect the membrane switch from the PC board. Remove the PC board. Lift out the latch assembly. Remove the 4 screws securing the control panel to the outer door. Gene. Hey Gene, Thanks! I appreciate the info! JD
