gitrman60
#1 Posted : Monday, May 21, 2012 4:44:37 PM(UTC)
gitrman60
It looks like the leak is coming from the pump. Should I just replace the whole pump assembly? If I buy the pump assembly, does it already have all the gaskets and seals in it? What about the seals for the motor shaft? Anything else that I'm missing?
Simon / APP Team
#2 Posted : Monday, May 21, 2012 6:12:23 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you will get the pump and motor complete assembly all you need to do is remove and replace it.
The motor /pump Part number: W10247394
Here are the breakdown diagrams and Replacement parts for Whirlpool DU840CWDB5 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
