hydertext
#1 Posted : Thursday, May 17, 2012 3:59:57 PM(UTC)
hydertext
Hi, the problem just started. The washer was working fine but now it stops in the middle of the wash cycle with a slight clicking sound. When manually advanced to the rinse cycle, it fails to drain and fill with fresh water.
Thanks for your help.
sidfink43
#2 Posted : Monday, May 21, 2012 4:36:21 PM(UTC)
sidfink43
I would start by replacing the timer. That is the most likely source of the problem.
hydertext
#3 Posted : Thursday, May 24, 2012 7:21:45 PM(UTC)
hydertext
Thanks sidfink43. I found out that the washing machine is getting un-stuck when I open up the lid and close it back again. it then runs through the full cycle (after being stuck for several hours). Do you think this might possibly indicate a problem with the lid switch?
sidfink43
#4 Posted : Friday, May 25, 2012 12:11:34 AM(UTC)
sidfink43
It is easy enough to check. Use a jumper wire to bypass the lid switch and see if that fixes things. If it does replace the lid switch as it is a safety item and must be in good working condition.
Guest (4)
