jatoba6
#1 Posted : Thursday, March 26, 2009 12:22:05 PM(UTC)
jatoba6
Ice door was not opening and stuck on crush but water working. Opened and discovered solinoid overheated and stuck closed. ordered new from you and installed but new solinoid not actuating. All switches appear to work and wireing is intact... Assume delay board?
TechnicianBrian
#2 Posted : Thursday, March 26, 2009 4:48:34 PM(UTC)
TechnicianBrian
If the solenoid was powered long enough to overheat, I would suspect the board was what started the problem. Verify the switches are working electrically (use a multimeter) and check for power to the board. If it is going in but not out, it must have failed.
jatoba6
#3 Posted : Friday, March 27, 2009 7:28:16 AM(UTC)
jatoba6
As I suspected, Thank you!
TechnicianBrian
#4 Posted : Friday, March 27, 2009 7:45:32 AM(UTC)
TechnicianBrian
Glad I could help.
Guest (4)
