mbertsch
#1 Posted : Thursday, March 26, 2009 3:14:04 PM(UTC)
mbertsch
Several Problems here...my mother-in-law cant reach inside the MW and often rotates the turn table. Now the turn table does not turn automatically. I can't get a new mother-in-law.:D ..tried that. Also, the door spring seems to be sprung....door just falls open when opened.
Need to know where to start, what parts are needed for both and a diagram that shows how to repair both...
Thanks...
TechnicianBrian
#2 Posted : Thursday, March 26, 2009 4:40:39 PM(UTC)
TechnicianBrian
Sounds like the torsion springs have failed on the door. I wrote about the repair in my post Replacing Microwave Torsion Springs and then while you are at it, you may want to go ahead and replace the turntable motor. It is hard to explain how to test that motor as it is not easy to get to, but while the unit is out to replace the springs, pulling it out a little more to do a resistance check of the motor shouldn't be much more work. If the motor reads as an open circuit, then it is bad, but I wonder if the motor is bad, or the coupler to the motor is stripped. You can lift up the plate and pull up on the coupler. See if it looks stripped or the plastic is damaged. It is also possible there is a control or wire harness problem but that requires some more trouble shooting and is rather involved. Start with the easy stuff, then go from there if need be.
Guest (4)
Avanti microwave issues (Microwave Repair)
by TOM2RN 5/8/2015 10:33:35 AM(UTC)
Microwave issues (Microwave Repair)
by andymatthews 7/27/2010 5:52:24 PM(UTC)
