timot52
#1 Posted : Friday, May 18, 2012 10:43:25 AM(UTC)
timot52
Dyer cycle thru and buzzer sounds but dryer will not shut off till door is opened
Simon / APP Team
#2 Posted : Friday, May 18, 2012 3:20:24 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Open the control panel, locate the resistor attached to the timer.
Check the resistance. Set you meter to the at least 10kOhms.
You should read about 3.77 KOhm.
If it's different - replace the resistor Part number: 31001484
If the resistor checks OK - then it's bad timer.
If the old one looks like this Part number: 53-1758
then it's still available, if it's bigger - no longer available.
Thank you. Post the results.
Simon.
