3 Pages<123>
Flynncory
#11 Posted : Wednesday, May 16, 2012 5:27:01 PM(UTC)
Flynncory
Hi, I have the f2e0 message showing on my kitchenaid gas stove. I'm having trouble removing the front panel so that I can try trouble shooting the control panel. I've removed the screws and the front panel is loose when I pull from the bottom but once I pull it up over the 4 exposed metal pieces it seems to still be stuck on the sides. Any help would be greatly appreciated. Cory
#12 Posted : Wednesday, May 16, 2012 5:43:31 PM(UTC)
Hi Cory,
What is the complete model number of the stove?
Flynncory
#13 Posted : Thursday, May 17, 2012 2:15:48 AM(UTC)
Flynncory
Hi Gene,
The model number is KGSA906. I also see the numbers 9762266 on the user guide...not sure if that means anything. Cory
#14 Posted : Thursday, May 17, 2012 5:31:32 PM(UTC)
Cory,
The model number you posted is incomplete. You can find it on the oven door frame or on the frame behind the bottom drawer. Verify and repost it please.
Flynncory
#15 Posted : Thursday, May 17, 2012 6:57:11 PM(UTC)
Flynncory
Hi Gene,
I was able to find the model number KGRA806PSS01. Thanks, Cory
#16 Posted : Monday, May 21, 2012 5:56:06 PM(UTC)
Hi Cory,
Sorry for the delay.
The instructions are attached.
- The control board Part number: 9762810
If you need the correct part number for the membrane switch, post the color of it.
Here are the breakdown diagrams and Replacement parts for Whirlpool KGRA806PSS01 30" Freestanding GAS OVEN CONVECTION | AppliancePartsPros.com
File Attachment(s):
Removing the EOC and the user interface.doc (1,014kb) downloaded 33 time(s).
Flynncory
#17 Posted : Tuesday, May 22, 2012 8:43:10 AM(UTC)
Flynncory
Gene,
Thanks so much for the info! Cory
#18 Posted : Tuesday, May 22, 2012 1:39:11 PM(UTC)
You are welcome Cory. Keep us posted.
sdobrovolny
#19 Posted : Friday, November 9, 2012 10:02:54 AM(UTC)
sdobrovolny
I a searching for a part for my double wall oven, model KEBS247DWH8, the part I need is 8300386, the control panel with membrane. I am having the problem of the error that says that the connection between the membrane and the control board has gone bad. I have not been able to find anyone who carries the replacement part. Is there anything I can try?
#20 Posted : Friday, November 9, 2012 1:37:21 PM(UTC)
Unfortunately this part is no longer available and no authorized substitutions have been identified.
Guest (10)
3 Pages<123>
