khtony
#1 Posted : Thursday, March 26, 2009 6:43:50 AM(UTC)
khtony
A burner on my cooktop is not working properly. It is a "dual burner" and the outside ring works but the inner ring does not turn on.
Do I need to replace a switch or do I need to replace the burner?
Thank you.
woodchuckie
#2 Posted : Thursday, March 26, 2009 8:46:27 AM(UTC)
woodchuckie
You have a selector switch to choose one or both elements. Make sure it's in the proper position.
I would inspect the element for broken coils. Sometimes you can see through the top with a good flashlight and spot a broken or burnt coil. You can also check with an ohm meter to see if it has continuity.
I have swapped the wires on a switch I knew was good to check the switch. You don't have to swap the red and the black wires. UNPLUG THE OVEN FIRST
Remove bosh burners from cooktop (Oven Repair (including Ranges and Cooktops))
by stevekauss 4/8/2024 9:58:44 PM(UTC)
Burner heating without cooktop being switched on (Oven Repair (including Ranges and Cooktops))
by nvreds 2/25/2024 10:40:40 AM(UTC)
Induction cooktop EHI965BA error E9 (Oven Repair (including Ranges and Cooktops))
by Guest 11/28/2023 8:00:28 PM(UTC)
Bosch Induction Cooktop NIT3065/UC Non-Responsive (Oven Repair (including Ranges and Cooktops))
by trishglxk 10/3/2023 9:18:30 AM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
How to remove the sticky screws in GE cooktop? (Oven Repair (including Ranges and Cooktops))
by Guest 4/9/2023 10:34:15 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Frigidaire FEF369CGSB - Strange Cooktop Behavior (Oven Repair (including Ranges and Cooktops))
by trymes 3/22/2023 5:59:36 PM(UTC)
Kitchen aid/whirlpool Induction Cooktop Fuses (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 8:42:15 AM(UTC)
THERMADOR COOKTOP PCG366G (Oven Repair (including Ranges and Cooktops))
by pjl2000 11/20/2022 6:48:33 PM(UTC)
Heartland cooktop elements (Appliance Parts)
by Guest 10/11/2022 11:30:11 AM(UTC)
Installing Frigidaire FGGC3047QS Gas Cooktop (Oven Repair (including Ranges and Cooktops))
by Samkat923 8/2/2022 7:26:14 AM(UTC)
Thermador cooktop, no spark or gas for XLO burners (Oven Repair (including Ranges and Cooktops))
by Guest 3/26/2022 5:48:44 AM(UTC)
Cooktop anamoly (Oven Repair (including Ranges and Cooktops))
by RodB 2/17/2022 2:08:20 PM(UTC)
KitchenAid Gas Cooktop Solenoid Diagnosis (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 1/17/2022 9:09:30 AM(UTC)
