GeneL56
#1 Posted : Monday, May 14, 2012 9:34:41 AM(UTC)
GeneL56
My problem is the fridge is warm and the (top) freezer is somewhat OK --ice cream melts/refreezes. I want to remove the back panel to see if the coils are frozen-up but I guess the icemaker will need to be removed first. I see the two main mounting screws: do I just slip the icemaker off of those screws and lay it down while I remove the back panel for inspection? Thanks.
GeneL56
#2 Posted : Tuesday, May 15, 2012 8:45:15 AM(UTC)
GeneL56
Answering my own question: I turned off the water supply to the fridge; turned off the power; then removed the three mounting screws (two on top, one on the bottom of the icemaker) and it came out without a problem. Was able to disconnect the electrical plug without a problem also.
Simon / APP Team
#3 Posted : Tuesday, May 15, 2012 11:39:01 AM(UTC)
Simon / APP Team
Rank:: Advanced Member
Groups: APP Team
Hi.
I'm glad you managed it on your own.If you need any help - just ask.
Simon.
Removing Icemaker (Refrigerator & Freezer Repair)
by cragin 1/14/2010 1:58:56 PM(UTC)
Permanently removing icemaker from Kenmore fridge? (Refrigerator & Freezer Repair)
by drs78 8/10/2008 9:41:37 PM(UTC)
