pcrellin
#1 Posted : Wednesday, March 25, 2009 8:08:25 AM(UTC)
pcrellin
Last Night we lost power. Today the wall oven had a code of E1 F1. I turned off the breaker for 30 seconds and same thing.
The stove top works, all lights on the display work. The oven does not get hot.
The oven is 9 years old. Is this the control panel? Or maybe just the transformer as I read in a thread? Are parts still availabel?
Whirlpool RBS305PD89
Thanks,
Pat
pcrellin
#2 Posted : Wednesday, March 25, 2009 8:15:20 AM(UTC)
pcrellin
This is propane. When we 1st saw the error code E1 F1, we tried the stove top and it would not light. After I turned off power for 30 seconds the stove top lights. Could this be the pilot light for the oven? I don't smell gas when we turn on the oven.
Pat
pcrellin
#3 Posted : Wednesday, March 25, 2009 8:17:06 AM(UTC)
pcrellin
OK, I see the oven is electric. go ahead and laugh.
pcrellin
#4 Posted : Wednesday, March 25, 2009 6:25:41 PM(UTC)
pcrellin
bump bump bump
#5 Posted : Thursday, March 26, 2009 1:34:29 AM(UTC)
Could not find info on the listed model number PD89, tech sheet is for a PDB9.
Hopefully this is correct.
Replacement parts for WHIRLPOOL RBS305PDB9 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%204451884.pdf
Looks like the code is an error on the control board.
Code seems to indicate it is a check sum error re: the integrated circuit is shot.
I would remove power from the unit overnight, some boards take quite a while to reset. A long shot but still worth a shot.
It is interesting that the board comes with an electronic filter (line conditioner), sort of indicates there have been a problems in this area (voltage spikes damaging the chip).
pcrellin
#6 Posted : Thursday, March 26, 2009 5:29:00 AM(UTC)
pcrellin
Great forum, thanks for the help.
I'll leave the power off for a day & see if that works.
I see the control panel takes 5-6 days to ship. Is that all I need? Can you direct me to insructions to r&r the control panel. I don't see any screws. Does everything pry off? Do I need to pull the oven out to get to the control board?
ladymp
#7 Posted : Thursday, March 26, 2009 1:31:26 PM(UTC)
ladymp
I Have Whirlpool Model Gw395leps00 Control Panel Keeps Blowing Out And Replaced After Less Than One Year Old The First Time. Whirlpool Claims No Problem
pcrellin
#8 Posted : Friday, March 27, 2009 4:42:20 AM(UTC)
pcrellin
Little help please.
Oven did not reset overnight. I'm trying to decide whether to call a repairman. Would like to do this myself.
Do I only need the control panel? Can anyone direct me to instruction to r&r the panel.
ladymp
#9 Posted : Friday, March 27, 2009 11:17:00 AM(UTC)
ladymp
researching whirlpool control panel on ovens; there has been a recall on their ovens in 2004 due to malfunctioning control panels. there are underlying problems causing the probems with current model a hard to reach fuse and ignition module. i have replaced control panel twice and it has blown for the third time.
pcrellin
#10 Posted : Friday, March 27, 2009 1:50:41 PM(UTC)
pcrellin
3 control boards? Sorry to hear that. I guess I'm going to call a repairman. Not getting much help on this forum.
Guest (4)
electric whirlpool oven wont heat (Oven Repair (including Ranges and Cooktops))
by wildgopher 2/27/2012 9:42:56 AM(UTC)
Whirlpool Oven Wont Heat (Oven Repair (including Ranges and Cooktops))
by Francish 11/30/2011 7:50:17 PM(UTC)
whirlpool oven wont heat up (Oven Repair (including Ranges and Cooktops))
by tim hinson 5/11/2011 3:49:42 PM(UTC)
