KenMoore
#1 Posted : Friday, November 30, 2007 9:31:45 AM(UTC)
KenMoore
The icemaker jammed a week ago because the cubes were not clearing out of the compartment correctly. The cubes did release from the mold. After removing the loose cubes, the icemaker made ice properly. This happened in the past year a few times and was fixed the same way. Two days ago, ice cubes were again loose in the compartment. The ejector arm did not move afterward. Ice was in the mold but the cubes seemed smallish. Removed the icemaker from the freezer. Found that the white plastic gear was pushed out from the grayish motor housing plate, enough so that the metal motor gear was not engaging the plastic gear. Half of the plastic center post tab holding the white gear in place was broken. Pushed the gear back in and reconnected the icemaker. The ejector arm did not move in 12 hours. Removed the icemaker again. Staring at it wondering if there is any way to test it or just buy a new one altogether. Any advice?
Samsung Icemaker Not working - French door (Refrigerator & Freezer Repair)
by mham99@gmail.com 2/2/2020 7:30:26 AM(UTC)
LG LFX25960ST icemaker not working (Refrigerator & Freezer Repair)
by dlehnhardt 6/21/2019 1:24:06 PM(UTC)
Icemaker not working (Refrigerator & Freezer Repair)
by jakiche 5/7/2015 6:19:40 PM(UTC)
KSCS25FTMS - Kitchenaid Fridge Lights/IceMaker Not Working - But Fridge/Freezer Work (Refrigerator & Freezer Repair)
by cgsauer 4/7/2015 5:25:13 AM(UTC)
Kenmore Icemaker not working (Refrigerator & Freezer Repair)
by belize2020 6/7/2013 3:27:07 PM(UTC)
Kitchenaid icemaker not working (Refrigerator & Freezer Repair)
by gmpfeffer 2/24/2013 1:42:19 PM(UTC)
GE Side by side icemaker not working (Refrigerator & Freezer Repair)
by Aleste 1/31/2013 3:51:41 AM(UTC)
2nd New Icemaker not working (Refrigerator & Freezer Repair)
by RonBuice 1/16/2013 4:14:41 AM(UTC)
GE Refridgerator Freezer and Icemaker Not Working (Refrigerator & Freezer Repair)
by redspider 12/17/2012 2:17:36 PM(UTC)
Kitchenaid Icemaker not working (Refrigerator & Freezer Repair)
by Stekelenburg 12/12/2012 9:55:44 AM(UTC)
LG icemaker not working (Refrigerator & Freezer Repair)
by AKFatBoy 9/26/2012 9:12:24 AM(UTC)
Maytag Side by Side - Dispenser/Icemaker not working after filter change (Refrigerator & Freezer Repair)
by geodon7 9/7/2012 10:00:31 AM(UTC)
Kitchenaid Fridge Icemaker not working (Refrigerator & Freezer Repair)
by lancecowell 7/12/2012 4:04:09 PM(UTC)
by RosemaryCheatwood 6/20/2012 8:55:29 PM(UTC)
LG Icemaker not working efficiently at all (Refrigerator & Freezer Repair)
by dony95 6/15/2012 4:17:52 AM(UTC)
