lemichie
#1 Posted : Thursday, May 10, 2012 6:30:32 AM(UTC)
lemichie
I first thought I had a blown fuse problem, but that wouldn't explain why it will still turn on when set to cool down, under the auto dry section. Now I'm thinking maybe it's the timer. If so, could this be an easy at-home fix or should I put a call out?
Can anyone shed light on this?
Thank you!
Simon / APP Team
#2 Posted : Thursday, May 10, 2012 10:25:50 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it's the timer.To replace it you need to open the control panel and take out two screws.
The timer Part number: 3979618
Here are the breakdown diagrams and Replacement parts for Whirlpool CEDS563SQ0 29" ELECTRIC DRYER | AppliancePartsPros.com
Good luck. Post the results.
Simon.
