AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Crosley Dryer--will only turn on in "cool down" on auto setting
I first thought I had a blown fuse problem, but that wouldn't explain why it will still turn on when set to cool down, under the auto dry section. Now I'm thinking maybe it's the timer. If so, could this be an easy at-home fix or should I put a call out?
Can anyone shed light on this?
Thank you!
Groups: APP Team
Joined: 2/12/2012(UTC) Views messages in topic : 5,556
Hi. Most likely it's the timer.To replace it you need to open the control panel and take out two screws. The timer Part number: 3979618
Dryer Repair
