rkokopelli
#1 Posted : Sunday, May 6, 2012 8:30:52 PM(UTC)
rkokopelli
My fresh food side is warm 52 degrees. Freezer is 0. Refer side was 52 with thermo set at 36 went to 50 when I set it to 34. Cannot feel any cool coming through the tunnel on refer side. Drain lines are clear. Bottom of machine is dust free. Coil in freeze is not iced. Whatcha think?
rkokopelli
#2 Posted : Sunday, May 6, 2012 8:32:51 PM(UTC)
rkokopelli
Help Please
rkokopelli
#3 Posted : Sunday, May 6, 2012 8:34:10 PM(UTC)
rkokopelli
PLease help asap
#4 Posted : Monday, May 7, 2012 1:28:04 AM(UTC)
Remove the freezer back panel and descibe the frost pattern, total, heavy frost, partial frost, or total, light frost?
rkokopelli
#5 Posted : Monday, May 7, 2012 7:11:07 AM(UTC)
rkokopelli
light to no frost
#6 Posted : Monday, May 7, 2012 11:34:15 AM(UTC)
The evaporator should be totally covered with light frost and have a temperature of nearly -20 degrees. If you wet a finger and stick it on a exposed coil it will stick to it. Looks like you have serious refrigeration problems, bad compressor/refrigerant leak.
GE monogram side by side not cooling (Refrigerator & Freezer Repair)
by Romanrart 5/17/2016 5:04:10 AM(UTC)
GE Monogram Side by Side - stops after 24hrs (Refrigerator & Freezer Repair)
by hstoor 3/29/2014 9:10:35 AM(UTC)
GE Monogram side by side standalone Dead! Please help (Refrigerator & Freezer Repair)
by chrisko 2/3/2013 5:46:27 PM(UTC)
GE Monogram Side by Side "Lava" Ice (Refrigerator & Freezer Repair)
by edonlon 11/19/2012 11:27:29 AM(UTC)
GE Monogram Side by side noisy damper door (Refrigerator & Freezer Repair)
by rcatty 2/6/2010 8:04:04 AM(UTC)
