jperrot
#1 Posted : Thursday, May 3, 2012 3:04:38 PM(UTC)
jperrot
Washer only works (drains & spins) in any spin cycle. It is dead in all the wash cycles. Replaced timer but that did not fix the problem. Replaced load sensor switch less than a year ago. Don't know where to go from here...???
#2 Posted : Friday, May 4, 2012 2:20:55 PM(UTC)
Does the motor run when it should agitate? Does it make any noise?
jperrot
#3 Posted : Saturday, May 5, 2012 4:22:51 AM(UTC)
jperrot
Thanks for replying. The washer is totally dead in all wash cycles but works properly to drain and spin in all cycles. I ordered a new load sensor switch hoping that will fix the problem. At first I replaced the timer but the problem remained.
#4 Posted : Monday, May 7, 2012 2:05:57 PM(UTC)
Check the washer speed switch (#28 at the diagram) according to the table from the attached tech sheet.
- The speed switch Part number: W10180780
File Attachment(s):
Wiring Sheet - W10177829 - WTW57ESVW.pdf (248kb) downloaded 8 time(s).
