Dee07
#1 Posted : Tuesday, May 1, 2012 7:19:36 AM(UTC)
Dee07
I have a whirlpool heavy duty extra large capacity plus washier and the agitator works intermittently. How do I diagnosis the issue and what needs to be replaced? It's about 8 years old and used about 4 times a week.
Simon / APP Team
#2 Posted : Tuesday, May 1, 2012 9:20:38 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please describe more detailed how the agitator acting and also provide the model number.
Thank you.
Simon.
Dee07
#3 Posted : Wednesday, May 2, 2012 4:10:33 AM(UTC)
Dee07
The model number is LXR9245EQ2.
At first the agitator was making a clicking noise like you could tell it was stuck. It's not making that noise but it's now not really moving at all. I can move it by hand freely but it doesn't did it on it's own.
Simon / APP Team
#4 Posted : Wednesday, May 2, 2012 8:13:08 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Is it the top portion of the agitator you are talking about or the hole agitator?
Simon.
Dee07
#5 Posted : Wednesday, May 2, 2012 8:53:59 AM(UTC)
Dee07
The whole agitator doesnt move, it seems to try to & vibrate but doesn't.
Simon / APP Team
#6 Posted : Wednesday, May 2, 2012 9:10:48 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Pry off the the top cap, remove the 7/16 bolt and pull out the agitator.
Turn the washer on and check if the transmission shaft is moving and you can't stop it by hand.
If the shaft is OK - replace the agitator base. If not - transmission.
The agitator base Part number: 3350830
The transmission Part number: 3360629
Here are the breakdown diagrams and Replacement parts for Whirlpool LXR9245EQ2 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Dee07
#7 Posted : Wednesday, May 2, 2012 2:10:28 PM(UTC)
Dee07
I reran the washer and this happened:
With just water the entire agitator moved. When I put some clothes in it the bottom part spun but the top did not.
Should I still do as you suggested?
Simon / APP Team
#8 Posted : Wednesday, May 2, 2012 8:59:03 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Now it's completely different picture. The problem is with so called "agitator dogs".
They are located inside the agitator between upper and lower part.
The agitator dogs Part number: 80040
Part number: 80040
Use the video clip for the instructions.
Good luck.
Simon.
