valovesnc
#1 Posted : Tuesday, May 1, 2012 3:18:34 PM(UTC)
valovesnc
About a year ago our dishwasher quit washing dishes. On any cycle it does the same thing. The water fills and then makes motor sounds like it is washing but the lower and upper water arms do nothing. Also at the end of cycles it empties the water.
Thanks you in advance for your assistance in diagnosing our dishwasher.
Val in NC
#2 Posted : Tuesday, May 1, 2012 4:59:05 PM(UTC)
Remove the bottom panel and touch the main motor to verify if it's working during the wash cycle. Post the results.
valovesnc
#3 Posted : Tuesday, May 1, 2012 6:22:01 PM(UTC)
valovesnc
Thanks for the reply. Yes the motor is making noise and virbrating
#4 Posted : Wednesday, May 2, 2012 12:07:09 PM(UTC)
Remove the lower spray arm, the spray arm support and the glass trap. Lift the filter up to remove. remove 3 screws and lift the pump cover off. Check the impeller. If it's moving very freely, the motor assembly has to be replaced.
- The motor kit Part number: 154859101
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
