pomeroys7
#1 Posted : Monday, April 30, 2012 7:24:56 AM(UTC)
pomeroys7
I have a leak in the door of this unit and I have already replaced the door seals and the door gasket is tight. Is there an other seal I am missing?
#2 Posted : Tuesday, May 1, 2012 5:26:05 AM(UTC)
Replacement parts for Frigidaire FBD2400KW2A DISHWASHER | AppliancePartsPros.com
By seals I assume you mean Item 49 in Section 2.
Did you also replace the splash shield kit AP4338941 as suggested in the parts info?
Check that the spray arm holes are clean. Sometimes you can get a partial plug which can spray out at a weird angle and cause a leak.
It may be just semantics but you said "in the door", if it is actually in the door then perhaps it is leaking around the dispenser.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Frigidaire dishwasher fills and drains does not wash (Dishwasher Repair)
by Guest 9/19/2023 12:06:34 PM(UTC)
Frigidaire Dishwasher Heating Element warped? (Dishwasher Repair)
by Guest 4/8/2023 10:48:21 AM(UTC)
I20 error on brand new Frigidaire dishwasher (Dishwasher Repair)
by Guest 2/8/2023 6:50:55 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
Frigidaire dishwasher Model # LFID2422RF4B (Dishwasher Repair)
by lharwerth 11/22/2021 7:15:45 AM(UTC)
Frigidaire dishwasher ffbd2406nb3a no cleaning the dishes (Dishwasher Repair)
by Yolando 4/6/2021 5:50:57 PM(UTC)
Frigidaire Dishwasher ffbd2411ns1a Noise (Dishwasher Repair)
by bdwashburn 8/3/2020 11:11:43 AM(UTC)
Frigidaire Dishwasher Won't Start (FFBD2406NS9B) (Dishwasher Repair)
by Radamis 8/3/2020 8:14:55 AM(UTC)
Frigidaire Dishwasher FDB1250REC0 no lights (Dishwasher Repair)
by Idesignedit 9/2/2019 9:37:32 AM(UTC)
Frigidaire Dishwasher FFBD2406NB0A (Dishwasher Repair)
by Brian P Mark 4/18/2019 4:54:21 AM(UTC)
Frigidaire Dishwasher LGID2475QF5A i20 error code (Dishwasher Repair)
by 210matt 11/4/2018 3:32:21 PM(UTC)
Frigidaire Dishwasher Soap Still Remains (Dishwasher Repair)
by Kryptonite 4/5/2018 12:21:21 PM(UTC)
*plz Help* Frigidaire Dishwasher Top Sprayer Will Not Work *plz Help* (Dishwasher Repair)
by Timma9705 2/21/2018 8:14:48 AM(UTC)
