genweld
#1 Posted : Monday, March 23, 2009 5:17:23 PM(UTC)
genweld
I did a diagnostic test C00-008 after the washer failed to drain. When it gets to C06 (drain) it won't advance to the next cycle and the pump makes a sound like it needs to be primed or the impeller is slipping. In the beginning of this problem I was able to get the tub to drain by running it empty on the Drain/spin option. I tried it again with no luck. I also tried unplugging the machine for a while with the hopes of reseting the computer. Still no luck. Any suggestions would be appreciated.
Tony
TechnicianBrian
#2 Posted : Tuesday, March 24, 2009 6:22:56 AM(UTC)
TechnicianBrian
Remove the lower panel and in the middle will the be while sump clean out. Have towels handy because any water inside the sump will quickly be in your lap. Open the clean out and see if it is full of 'stuff' that may be slowing the flow of the drain water.
genweld
#3 Posted : Tuesday, March 24, 2009 7:04:55 AM(UTC)
genweld
Hi Brian,
Thanks for responding. I did check the cleanout and it was clear. I tried the diagnostics angain and when it got to C06 (drain) the pump sounded like it needed to be primed or the impeller was slipping. It would not advance to the next cycle. Do you think it's time for a pump/motor assembly. Washer is about 5 yrs. old.
Thanks again
Tony
TechnicianBrian
#4 Posted : Tuesday, March 24, 2009 5:12:07 PM(UTC)
TechnicianBrian
It sounds like water may be remaining the in the sump area, and if you are hearing cavitation sounds, and the sump is clean, I would pull the pump off the side of the clean out and see if the impeller is loose on the motor shaft, or even has a broken fin or two. The result will still be to replace the pump, but at least you would know what was going on.
genweld
#5 Posted : Wednesday, March 25, 2009 1:08:44 PM(UTC)
genweld
Hi Brian,
I will do what you suggest. However, I'll add this little twist. My wife can do light loads of wash and the washer works normally. If she tries to do a heavier load like jeans or towels the washer won't drain, and pretty much stops at that cycle. If everything checks out OK with the pump do you think it could be some kind of sensor.
Thanks again.
TechnicianBrian
#6 Posted : Wednesday, March 25, 2009 1:47:04 PM(UTC)
TechnicianBrian
You may want to do the pressure switch tests to verify it is working OK. The amount of water is monitored by the pressure switch as set by the control board. You mentioned the pump sounds like it needs to be primed, and I am assuming this is while there is still water in the tub. I am wondering the reason for the noise if there is water to pump. If the pump clean out is not blocking the flow of water, is there anything possibly in the sump (the rubber hose connecting the tub to the pump) that may be slowing the flow? A larger load is going to use more water than an small load so it may not be able to drain quick enough. If you are running the diagnostics and it won't go past the drain test, I would again look into the operation of the pressure switch, and then the control board. But verify there is absolutely noting that is blocking the flow of water. You wouldn't believe the things I have pulled from sumps.
Guest (4)
Maytag Neptune mah9700a won't drain ...(locking issue?) (Washer Repair)
by Mr.Petes 8/4/2023 4:55:48 AM(UTC)
won't drain completey (Washer Repair)
by Guest 2/5/2023 11:06:41 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
GE top load won't drain or spin (Washer Repair)
by Guest 2/15/2022 10:42:41 AM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Maytag washer won't drain with clothes (Washer Repair)
by Guest 7/8/2021 3:20:36 PM(UTC)
Won't drain automatically but it will drain if set manually to spin cycle (Washer Repair)
by adanpro@gmail.com 6/1/2021 6:47:55 AM(UTC)
Kenmore he 3T won't drain/spin, F2 (Washer Repair)
by corvairdoug 8/20/2020 2:23:35 PM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Won't drain,rinse or spin. (Washer Repair)
by dertikop 3/25/2017 5:46:57 AM(UTC)
Washer won't drain (Washer Repair)
by jpowell1978 2/23/2017 5:58:30 PM(UTC)
Maytag won't drain... (Washer Repair)
by HyKlas 2/21/2017 5:34:29 PM(UTC)
