firefly
#1 Posted : Friday, April 27, 2012 10:18:46 AM(UTC)
firefly
originally saw sparks from control panel. left us with no spin cycle.
I replaced the timer. The machine will click on for load and rince, but I get nothing on spin. What's up?
Simon / APP Team
#2 Posted : Friday, April 27, 2012 10:45:03 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please describe more detailed what is the washer doing.
Simon.
firefly
#3 Posted : Friday, April 27, 2012 11:00:04 AM(UTC)
firefly
The control panel was loose from the machine. Wife asked me to reattach, but I told her to use it as is until I got to it. She began seeing sparks from back of the control panel when she began a load. I observed sparks as the cycles changed. I replaced the timer, but now washer fills and does NOT agitate or spin. It just sits there full of water. Just like before, but without sparks.
Simon / APP Team
#4 Posted : Friday, April 27, 2012 11:25:10 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First of all check all the wires inside the control panel.
Next, check the continuity of the lid switch. Less then 1ohm between Gray and White with the lid closed. You can install the jumper wire for the "life" test.
Next, check continuity at the water level switch contacts V to T. With tub full of water should read less then 1 ohm.
The lid switch Part number: 8318084
The water level Part number: W10339251
Here are the breakdown diagrams and Replacement parts for Maytag MTW5620TQ1 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
firefly
#5 Posted : Friday, April 27, 2012 12:50:08 PM(UTC)
firefly
simon, sorry but I don't understand how to install jumper wire for "life" test. I don't know what you mean. Can you guide me?
Simon / APP Team
#6 Posted : Friday, April 27, 2012 4:12:50 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Firefly.
Get a 5in electrical wire 14 gauge or so, strip 1/4 in off each end.
Unplug the washer.
Incert jumper ends into lid switch terminals with Grey and White wires.
Plug in washer and start the cycle.
To do all this you need to open the control panel.
Thank you.
Simon.
firefly
#7 Posted : Sunday, April 29, 2012 7:36:54 AM(UTC)
firefly
simon, I have followed your instructions and jumped the lid switch. Everything seems to be working. I will asume this means I need a new lid switch. I would also like to know if we could do a couple of loads while waiting for the part, or am I risking further damage? Thanks for all your help.
Simon / APP Team
#8 Posted : Monday, April 30, 2012 10:52:43 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I don't think that you will damage the washer more then it's already, but there is a very serious risk of getting hurt by reaching into a spinning tub.Consider that.
Thank you.
Simon.
Guest (6)
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
No spin cycle on washer...need help (Washer Repair)
by 1moretoy 11/4/2014 3:57:35 PM(UTC)
Frigidaire Stackable Lid Switch Bypass no spin cycle (Washer Repair)
by billumd 9/26/2014 6:51:48 PM(UTC)
no spin cycle so clothes stay wet (Washer Repair)
by pmt1231 6/3/2014 8:23:30 PM(UTC)
Maytag Atlantis No Spin Cycle Replaced Thrust Bearing. (Washer Repair)
by MarkBe 12/21/2013 7:36:46 AM(UTC)
kenmore ~ no spin cycle (Dishwasher Repair)
by chrismo13 8/10/2013 12:42:54 PM(UTC)
No Spin Cycle (Washer Repair)
by KJH1961 1/16/2013 2:36:43 PM(UTC)
No spin cycle (Washer Repair)
by baldguywithagoat 10/8/2012 1:56:22 AM(UTC)
I replaced maytag mav6200aww brake, now no spin cycle (Washer Repair)
by jmlaudate 9/4/2012 4:28:43 PM(UTC)
Washer tumbles but no spin cycle (Washer Repair)
by jrwhitton 8/8/2012 9:13:05 AM(UTC)
Tumbles but no Spin Cycle (Washer Repair)
by Rob2001 7/23/2012 2:33:29 PM(UTC)
by John Foley 4/29/2012 11:46:11 AM(UTC)
No spin cycle or drain? Lid switch? (Washer Repair)
by 9n1Ed 4/27/2012 10:47:15 PM(UTC)
GE washer no spin cycle (Washer Repair)
by fsuglover 4/8/2012 4:41:33 PM(UTC)
Maytag no spin cycle (Washer Repair)
by Cclcectcmc 12/8/2011 6:56:08 PM(UTC)
