:cool: INEED TO KNOW WHAT PART TO CHANGE FREZEER WORKS
Originally Posted by: FAUDEL  :cool: INEED TO KNOW WHAT PART TO CHANGE FREZEER WORKS HOW MUCH WOULD COST
Your model number seems to be missing the first 3 digits. Kenmore numbers are usually 3 digits, a period and then 6 to 8 digits.
Will also need a better description of the problem. What is running, re: condenser fan, evaporator fan, compressor? What are the freezer and fresh food temperatures, if you have measured them? Anything else that has changed since the unit ran OK? |
THIS FORUM IS DEAD!!!!!!! |
