PTinc
#1 Posted : 16 years ago
PTinc
I have a combo oven microwave unit, the Whirlpool RM280pxbb2. the oven continues to work perfectly but the microwave will not run. The lights come on, the timer counts down but there is no heat or activation of the microwave unit. Everything appears to be in order but there is just nothing happening. Looking for some guidance on how to fix myself. Have taken faceplate off and looked at hardware but do not know where to begin.
Looking for assistance. Thanks
pete
#2 Posted : 16 years ago
Open the control panel and check all door switches for continuity with door open and closed. Post the results.
Here are the break down diagrams and Replacement parts for WHIRLPOOL RM280PXBB2 | AppliancePartsPros.com
PTinc
#3 Posted : 16 years ago
PTinc
Thank you for your reply to my post but i am having issues with the Microwave and not the oven, which was the posted part "Cabinet Parts" that was posted. all the Door contacts are in order, i am not able to test them though. which door contact has to do with the activation of the Microwave mechanism? or is that not how the Microwave mechanism is started. Because the Timer counts down on the microwave the lights turn on like it is working but the actual "motor" part does absolutely nothing!!!!!
keep the help coming.
thanks
pete
#4 Posted : 16 years ago
Pete,
I said nothing about the oven. Click on the link in the previous reply and scroll down the menu on the left side. The diagram #3 is "Control panel" and the diagram #4 is "Door and latch" with the door switches shown. You have to have a simple multimeter to perform the tests.
