djralo
#1 Posted : Tuesday, April 24, 2012 11:24:56 AM(UTC)
djralo
i have a Whirlpool SGDS800JQ2 GAS DRYER the igniter wont turn on i replaced it with a new 1 but it still wont turn on
#2 Posted : Tuesday, April 24, 2012 2:01:18 PM(UTC)
Very likely the problem is a bad thermal fuse (#7 at the diagram). For the test ONLY you can bypass it to see if the ignition will work.
If the thermal fuse is the culprit, it has to be replaced together with the cycling thermostat (#9). At the same time you have to clean the dryer inside and the dryer vent line.
- The thermal fuse Part number: 3392519
- The cycling thermostat Part number: 3387134
gas dryer repair (Dryer Repair)
by allijackjackalli 1/29/2012 11:04:06 AM(UTC)
Gas dryer repair (Dryer Repair)
by kel4dolphins 10/7/2011 5:03:15 AM(UTC)
Natural Gas Dryer Repair (Dryer Repair)
by LAL 7/27/2009 6:48:47 PM(UTC)
propane gas dryer repair (Dryer Repair)
by SusieE 6/30/2009 8:57:10 AM(UTC)
by James Hazley 6/4/2009 3:14:36 PM(UTC)
by cackerman 1/9/2009 2:34:06 PM(UTC)
