kdsudz
#1 Posted : Monday, August 1, 2011 5:09:36 PM(UTC)
kdsudz
Washer won't run. Red light on front is on indicating that washer has been started. Tenant may have opened the door after washer was started.
Is there a reset button if this is what has happened?
sidfink43
#2 Posted : Wednesday, August 3, 2011 5:20:13 PM(UTC)
sidfink43
This forum is primarily devoted to residential machines and most of us, certainly myself, do not work on coin operated machines.
I can only suggest you try a forum that does address problems with commercial units.
Sorry, good luck.
agarrido
#3 Posted : Sunday, April 22, 2012 3:23:09 PM(UTC)
agarrido
DId you get this fixed? I have same problem.
Can you tell me what it was?
