Washer won't run. Red light on front is on indicating that washer has been started. Tenant may have opened the door after washer was started. Is there a reset button if this is what has happened?
This forum is primarily devoted to residential machines and most of us, certainly myself, do not work on coin operated machines.
I can only suggest you try a forum that does address problems with commercial units.
Sorry, good luck.
DId you get this fixed? I have same problem. Can you tell me what it was?
